Nadi Posted September 30, 2010 Report Share Posted September 30, 2010 Hi guys!!!i cam across the 13.8V 20A power supply project by Santa Cruz http://www.electronics-lab.com/projects/power/002/index.htmlFisrt, thank you very much for this informative project!second, i have some question,i have a transformer who get 220v as input and on the output it give 17~18v 400VAmy question is are this transformer can handle 30A right? 33.3A (400/12)so if i am did not wrong, how can i use this transformer in this circuit? i mean to get 30A output? what should i change? Thank you very much,and sorry for my poor English. Quote Link to comment Share on other sites More sharing options...
audioguru Posted September 30, 2010 Report Share Posted September 30, 2010 I came across the 13.8V 20A power supply project by Santa Cruz.I have a transformer which has 220v as input and on the output it gives 17~18v at 400VA.Can transformer handle 30A? 33.3A (400/12)No.Your transformer has a max output of 17V to 18V at 400VA. Then its max output current is 400/17V= 23.5A. Quote Link to comment Share on other sites More sharing options...
Nadi Posted September 30, 2010 Author Report Share Posted September 30, 2010 HO, you right thank you, 12 is only after the bridge and DC...but i still need to change some materials here.... am i right? Quote Link to comment Share on other sites More sharing options...
Hero999 Posted September 30, 2010 Report Share Posted September 30, 2010 Yes,you need a larger transformer amongst other things. Read the text associated with the project: it gives a clear explanation of how it works and how to alter the current limit. Quote Link to comment Share on other sites More sharing options...
Nadi Posted September 30, 2010 Author Report Share Posted September 30, 2010 yes i have a larger transformer and i read the text but i dont know witch part in need to put... Quote Link to comment Share on other sites More sharing options...
Guest Artk Posted May 2, 2014 Report Share Posted May 2, 2014 Hi there, I also reproduced http://www.electronics-lab.com/projects/power/002/index.html but I need your help to regulate tension from 1.5 to 14V, so I'll appreciate your suggested wiring and component values if I'm considering connect 7812 IC1 in ground terminal to a P2. Thanks and regards. Quote Link to comment Share on other sites More sharing options...
