Sign in to follow this
Detecting air flow
Hi all,
I'm new to these forums... I have some knowledge and experience with electronics but I'm no expert.
I'm interested in working on a project which would involve measuring the air flow through a pipe. The air could flow in both directions and could change direction suddenly - the sensor would need to report both the speed (or the pressure) and the direction. The speeds and pressures involved would be low and the readings would be ultimately be sent to a PC, so I'd prefer to use 5V components (although 12V would be acceptable).
The main consideration is that it should be very responsive - especially when a change of direction occurs. I would like to get a response in the order of 100 milliseconds rather than seconds. Accuracy of the speed measurement is not critical.
I don't really know what kind of sensor I should be looking at for these requirements, so I'd welcome any suggestions. Of course, it may be difficult to accomplish all this with a single sensor, so I could perhaps use two sensors with non-return air valves to cover both directions.
Thanks for any ideas!
Share this post
Link to post
Share on other sites
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
