walid Posted October 26, 2010 Report Share Posted October 26, 2010 Hithis is the circuitthanks Quote Link to comment Share on other sites More sharing options...
Hero999 Posted October 26, 2010 Report Share Posted October 26, 2010 Google for Joule Thief and if that doesn't answer your question Google for blocking oscillator. Quote Link to comment Share on other sites More sharing options...
walid Posted October 28, 2010 Author Report Share Posted October 28, 2010 Thank you hero999 it helped me Quote Link to comment Share on other sites More sharing options...
Kevin Weddle Posted October 28, 2010 Report Share Posted October 28, 2010 Hello Walid, I have never seen an LED in parallel with a 2N3904 transistor. Does it have current gain, voltage gain, or both? The power source doesn't have a voltage value. Quote Link to comment Share on other sites More sharing options...
audioguru Posted October 29, 2010 Report Share Posted October 29, 2010 Hello Walid, I have never seen an LED in parallel with a 2N3904 transistor. Does it have current gain, voltage gain, or both? The power source doesn't have a voltage value.It is a simple transformer-coupled oscillator and voltage stepup circuit. Its output voltage is as high as the LED forward voltage which is about 3.5V for a white or blue LED.It works with a "dead" 1.5V battery that is about 1V. It keeps working until the battery voltage drops to about 0.3V.The internet has some wrong explanations about how it works. I found a correct explanation and schematic: Quote Link to comment Share on other sites More sharing options...
steven Posted October 29, 2010 Report Share Posted October 29, 2010 thats a joule thief circuit it sucks the last remaining power out of a dead battery and are very usefull ive biult a number of these and have a bigger one i use to recharge my watch battery with and desulphate my 12 volts slr battery Quote Link to comment Share on other sites More sharing options...
steven Posted October 29, 2010 Report Share Posted October 29, 2010 :) heres the 2 bigger joule thiefs i used to recharge flatt button cell watch batteries and desulphate dead sla batteries and even charge a photoflash capacitor to Quote Link to comment Share on other sites More sharing options...
steven Posted October 29, 2010 Report Share Posted October 29, 2010 :) Quote Link to comment Share on other sites More sharing options...
Kevin Weddle Posted October 29, 2010 Report Share Posted October 29, 2010 Instead of an LED, could you use a diode and a small light bulb in series? Maybe a single 1.5V battery to power the small bulb? It looks like the component values would be difficult to determine in order to get it to oscillate. Quote Link to comment Share on other sites More sharing options...
Hero999 Posted October 29, 2010 Report Share Posted October 29, 2010 No because it's not powerful enough to power an incandescent lamp.If you need to run a small incandescent lamp from a single AA battery then buy one which is rated to 1.2V Quote Link to comment Share on other sites More sharing options...
Kevin Weddle Posted October 29, 2010 Report Share Posted October 29, 2010 Well of course. It's an interesting circuit which Steven has built and works. It is difficult to expect circuits to function unless the component values are exact and the design accounts for component tolerances. Quote Link to comment Share on other sites More sharing options...
audioguru Posted October 30, 2010 Report Share Posted October 30, 2010 The Joule Thief is a very simple transformer-coupled blocking oscillator with very few parts.Almost any amount of turns on the transformer will work and a power transistor can be used (like Steven did) when the base resistor value is reduced.It is such a simple circuit (using positive feedback which causes oscillation) that component values and tolerences hardly make any difference. Quote Link to comment Share on other sites More sharing options...
steven Posted October 30, 2010 Report Share Posted October 30, 2010 :)heres another one Quote Link to comment Share on other sites More sharing options...
steven Posted October 30, 2010 Report Share Posted October 30, 2010 :)heres the one that i biult from one of the circuits featured on youtube that i used to desulphate my 12 volts sla battery and charge a photoflash cap up enough for its neon to come on. i brought 7 meters of insulated red wire and 7 meters of black and i wound more than 90 turns , i thread the pair of wires through the inductor ring about a meter then wound that on clockwise then when it was done i got the longer bit left and wound that over the first winding counter clock wise so i made mine a bifilar wound clockwise and counter clockwise wound , its not that i dont know if the way i wound it makes any difference but it was just an experiment Quote Link to comment Share on other sites More sharing options...
Hero999 Posted October 30, 2010 Report Share Posted October 30, 2010 :)heres the one that i biult from one of the circuits featured on youtube that i used to desulphate my 12 volts sla battery and charge a photoflash cap up enough for its neon to come on. i brought 7 meters of insulated red wire and 7 meters of black and i wound more than 90 turns , i thread the pair of wires through the inductor ring about a meterWell I don't see the point of the neon. If the current is low enough for the neon to light without blowing up, it will have a maximum current rating of something liek 10mA so it can't have a high enough current to charge a SLA. The neon could just as easily be replaced with an LED and it will work fine. then wound that on clockwise then when it was done i got the longer bit left and wound that over the first winding counter clock wise so i made mine a bifilar wound clockwise and counter clockwise wound , its not that i dont know if the way i wound it makes any difference but it was just an experimentIf you wound it clockwise then winding anticlockwise will reduce the inductance because the magnetic fields cancel. For example, a transformer with a 20 turn secondary, with 5 of the turns wound in the opposite direction to the rest, will be equivalent to the same transformer with a 10 turn secondary, 15 - 5 = 10. Winding in the opposite direction is counter productive because it increases the series resistance. You're circuit would be better if you simply removed the turns wound in the opposite direction. Quote Link to comment Share on other sites More sharing options...
steven Posted October 30, 2010 Report Share Posted October 30, 2010 :) and yet it works fine no problems and never had the neon blow out at all and i charged a photo flash capacitor up to the voltage rateing of the neon and it light up well . heres a picture of it the pink glow comes out on film but not when you look at it directly , and dispite haveing some counter clockwise wounds it still works like the one featured on youtube and for 12 volts i got much more voltage output than i put into it so if my conter clockwise turns do any cancelling out then why do i still get more than i put into it as for the neon well i followed the giudelines on youtube and put it in and it works fine in fact what you see on the project box pannel was originally a 12 volts dc gl;obe auto globe but i converted it to hold a 90 volts neon , ill tell you exactly how much voltage output i measured when i find my notes in amoungst all the 169 gigabytes hardrive Quote Link to comment Share on other sites More sharing options...
Hero999 Posted October 30, 2010 Report Share Posted October 30, 2010 :) and yet it works fine no problems and never had the neon blow out at all and i charged a photo flash capacitor up to the voltage rateing of the neon and it light up well . heres a picture of it the pink glow comes out on film but not when you look at it directly ,The neon is pink because it's ridiculously overdriven. The colour is different at higher currents because the lamp pressure will be higher and other gasses in the mix will be ionised.It works but for how long? The neon will eventually burn out. and dispite haveing some counter clockwise wounds it still works like the one featured on youtube and for 12 volts i got much more voltage output than i put into it so if my conter clockwise turns do any cancelling out then why do i still get more than i put into it as for the neon well i followed the giudelines on youtube and put it in and it works fine in fact what you see on the project box pannel was originally a 12 volts dc gl;obe auto globe but i converted it to hold a 90 volts neon , ill tell you exactly how much voltage output i measured when i find my notes in amoungst all the 169 gigabytes hardrive You didn't read my post properly, I didn't say it wouldn't work, just that the way you've wound it makes it less efficiency. Try removing the extra turns, it will be more efficient.The voltage across the neon will also be much less than 90V with the high current you're putting through it.Did you measure the current with a true sine wave meter or an oscilloscope with a current probe or sense resistor? Don't bother trying to use a meter, the reading won't be accurate. Quote Link to comment Share on other sites More sharing options...
steven Posted October 30, 2010 Report Share Posted October 30, 2010 :)my atempt at posting my note failed its to big i geuss theres not enough room here to upload it all Quote Link to comment Share on other sites More sharing options...
Hero999 Posted October 30, 2010 Report Share Posted October 30, 2010 How large is the file?I just reread your post and noticed something else:heres a picture of it the pink glow comes out on film but not when you look at it directlyThe fact that it appeard pink on film but not when you're looking at it implies it's emitting invisible radiation, probably UV, try putting some white paper next to it to see if it glows blue. Quote Link to comment Share on other sites More sharing options...
steven Posted October 31, 2010 Report Share Posted October 31, 2010 :)that reminds me of a chemistry lab night club i was once taken to everything on the wall behind the bar was test tubes and flurescent stuff that glowed and the lights were purple and everyone who wore a white shirt glowed purple ill try that see what effect it has on paper latter when i get to it , oh the night was called dr feel goods chemistry lab night club, years ago but its no longer there Quote Link to comment Share on other sites More sharing options...
Hero999 Posted October 31, 2010 Report Share Posted October 31, 2010 Everything glowed in the nightclub because it was lit with blacklights which are just fluorescent lamps which emit long wavelength UV.I've never tried it myslelf but I've heard that UVA appears pink when looked at with a CCD in a digital camera.What colour does the neon appear to you? It might be bright red/orange but there will certainly be some invisible UV in there. Quote Link to comment Share on other sites More sharing options...
steven Posted October 31, 2010 Report Share Posted October 31, 2010 :)hm if i rememeber corectly without going through my massive notes the neon glowed sort of orange colour i have videos to . some years ago i did an experiment where i had a neon light and by adjusting the frenquency output to the neon i got red green and orange and blue glows and thats years before i found out they have got colourd neon globes out on sale here that glow other colours Quote Link to comment Share on other sites More sharing options...
