Jump to content
Electronics-Lab.com Community
Need help for project. 12v Regulator
nugab
Hey all, Nathan here.  I'm new to this board, and looking for some tips.
I'm new to electronics.
I am making a portable video streamer.  It's ghetto, and there are a slew of easier ways to meet my goals, but these are the parts I have available, and so I want to try and find a way to make it work.
I have an Anton Bauer battery that is typically 16vdc, but can fluctuate 12v-17v.  It's an 8 amp source.
I'm trying to power a 12v encoder, that may require up to 2.5 amps.
I have several small 12v solid voltage regulators from radio shack (I don't hace access to the P/N right now), at first they seemed perfect.  But they can only supply up to 1 amp.
I know so little that finding the right part is becoming more and more frustrating.  After this project I plan to spend a good amount of time getting up to speed, possibly taking some electronics classes.  I would love to finish this first though.
I considered 3 of the Radio Shack regulators I have in series.  From my online research it seems likely that I could reach my target of 12v, with enough current to supply 3 amps.  But I'm not confident enough to test it out on my only encoder.
I went to a store in town and got the closest thing I could identify as a possible solution.
A nte970 Linear Integrated Circuit 3-Terminal Adjustable Positive Voltage Regulator.
What a name!
There are some inherent flaws with this part.
Firstly, apparently my knowledge is far too lacking to know what to do with it.
Secondly, it's called a "3-terminal regulator", but it only has 2 terminals to my eyes.
I'd love some help.  I don't mind buying a regulator or some various other part.  I just want this to work.
Sorry for the long post for such a simple problem.  I'm prone to long-windedness.
Thanks for your time.
-Nathan
Link to comment
Share on other sites
Why were you even considering putting three regulators in series?
The output current would remain the same but the drop-out voltage would triple.
Assuming the encoder will be damaged by 17V (it might be able to work of that voltage fine) you need a low drop-out regulator, otherwise the battey life will be poor.
I've found the datasheet for the nte970 and it doesn't sat what the drop-out voltage is but it's characteristics specified with the output voltage 3V below the input so it's probably similar to the LM317: about 2.5V. This means that when your battery voltage drops to 12V, the output voltage will be 10.5V.
http://www.nteinc.com/specs/900to999/pdf/nte970.pdf
A more detailed explanation of what the drop-out voltage is can be found in the thread linked below:
http://www.electronics-lab.com/forum/index.php?topic=24319.msg100192#msg100192
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
