xsumirx Posted May 5, 2012 Report Share Posted May 5, 2012 Hello,Actually I am designing a Digital Voltmeter using ICL7107. Having capability to measure 0-200v with 0.1 resolution.My Problem is, when I connect the output of 7805 and 7905 to ICL7107 at Pin 1 and 26 respectively. the output voltage become zero at the out pin of 7905 as well as 7805.and not even a single 7-seg Display showing any outputPlease help me !!!! :'(I am not able to Judge weather its the Problem with my PSU or ICL7107.I have attached my PSU ...... ??? ??? Quote Link to comment Share on other sites More sharing options...
Hero999 Posted May 5, 2012 Report Share Posted May 5, 2012 How are we supposed to help without a schematic?I did a quick Google for the typical configuration for the said IC and assuming you're using the standard set-up I don't know why you're surprised, you're short circuiting the power supply. Quote Link to comment Share on other sites More sharing options...
xsumirx Posted May 6, 2012 Author Report Share Posted May 6, 2012 you're short circuiting the power supply.If I have done any Mistake with my Power Supply.. Then can you Please Figure it out !!!! ??? ???and I have also attested the Schematics of the Digital voltmeter ??? ??? ??? Quote Link to comment Share on other sites More sharing options...
Hero999 Posted May 6, 2012 Report Share Posted May 6, 2012 All right, you're not trying to do what I thought which was measuring its own power supply.The first thing which could be wrong is the 7660 isn't needed, as you already have a negative supply, so it needs removing.Secondly, what's the transformer's voltage rating? The filter capacitor values appear to be too small.And Finally, have you made all the 0V connections? Quote Link to comment Share on other sites More sharing options...
