Jump to content
Electronics-Lab.com Community
Sign in to follow this
Guest trekkiejonny
What are the most used electronic components?
Guest trekkiejonny
I have recently been getting more and more into hobby electronics. I believe that I would one day like to make a career out of this. There is an electronics surplus store that I get components from but unfortunately it is a 2 hour drive away. At this place the components are very cheap, like pennies for 10, and there are just so many shelves full of trays with what looks like everything I could ever want.
My questions is, what components are the most used? What should I stock up on?
What ranges of Capacitors, Resistors, Diodes, and Inductors would I be using the most starting out in electronics?
Are there any other components I should get while am at it? ICs, Transistors, Relays, Motors, etc? I want to get into Radio and Robotics once I get a grasp on the basics.
Thanks for any and all help
Share this post
Link to post
Share on other sites
Guest harrymann
All sorts of electronic components have a particular usage for any electronic devices. Nevertheless, I guess OP-Amps, Resistors, Diodes, Capacitors and Inductors are the most common electronic components.
Share this post
Link to post
Guest remonx6
Electronics components arrange with Resistor,diode,inductor and also capasitors. because those are uses every time as an electronics components.
Share this post
Link to post
I think membrane switch...
Membrane switches are the modern version of mechanical types and are meant to deliver exceptional performance when put inside dominant devices. These are just short switches that are widely employed in many electronic appliances today.
These switches are now highly preferred over the traditional ones as they come with customizable options. They are incorporated with print copper or silver because of the main circuit layer. They can be non-tactile or may have a tactile response which then makes the device fast and minimizes its operation time. They also provide the very best level of responsibility, execution, and integration, which are required today as we need precise switches to run advanced and sensitive electronic switches.
Share this post
Link to post
There are so many electronic components like.
1-Resistor.
2-Capacitor.
3-Diode.
4-Transistor.
5-Integrated Circuit (IC)
6-Relay.
7-Inductor.
8-Crystal.
I need this electronic component so I could not find any component. After a few days, my friend told me about GREATPCB.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
