Guest mshh Posted November 29, 2013 Report Share Posted November 29, 2013 I am doing maximum power tracking (MPPT)for a photovoltaic cell (max current 4.4 A ,max voltage 34 v) i did the attached circuit to control current consequently get MPPT but the circuit go mad when i turned the potentiometer the current go up and down and didn't stabilize .I used this power supplyhttp://www.amazon.com/Mastech-HY3005.../dp/B000E14F56 to simulate the pv panel and adjust it to source 7 volt and it did well . i could change the current from 0-2 A when i tried to increase it upper than 7 v it went crazy . the led indicator called C.C changed to C.V every thing current and voltage go upside down ,and that what was happening with the pv panel. i don't know why . may be i should increase the number of mosfets.but i used four resistors 3.3Ω 7 watt instead of those in picture Quote Link to comment Share on other sites More sharing options...
Guest Jibby Posted April 21, 2014 Report Share Posted April 21, 2014 You can try a model number 213 from website www.edgefxkits.com Quote Link to comment Share on other sites More sharing options...
