Jump to content
Electronics-Lab.com Community
Describe the design of a simple home automation system
Guest ca123ner
Guest ca123ner
hi,
Describe the design of a simple home automation system. The required functionalities of the system are:
- Temperature and ventilation control
- Lighting control
It should be possible for the user to set some parameters of the system like required temperature, humidity or time at which the electric light should be reduced or turn on/off in a particular room and at selected time. Also an automated mode should be provided in which the system adjusts conditions according to the number of people in a room and the day time. The system should be connected to the Internet network to provide the remote control functionality for the user.
Design the structure of the system, select components and sketch the structure of the system software.
I dont know how to do it.Can you help me about this topic.
thank you,
Link to comment
Share on other sites
  • 3 months later...
  • 3 weeks later...
I designed a sensor interface for a computer if that helps.
http://sites.google.com/site/angophoraelectronics/projects/temperature-humidity-sensor
  Micro-controller                    ATMEGA8A
  Humidity sensor                    HONEYWELL HCH-1000-002
  Temperature sensor              LM335AZ
  Crystal                                  3.6864 MHz
  Serial interface                      MAX232
  Humidity Sensor Interface    74HC4060
Component cost is about $36 USD.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
