Guest thebignoob Posted August 21, 2014 Report Share Posted August 21, 2014 Hello, I was using USART interrupts to handle data transfer from PC to uC so that I could send that data to another remote PC using nRF24L01. Everything worked just fine with ATMega88, but on one side i had to switch to ATMega168 and then... :( :( :( everything stop working ...So I tried to debug it... one thing at the time... USART communication is working when I send some data from PC to uC and back... But when i try to do that using USART interrupt problem occurs... When I enter any character from terminal it goes crazy .... starts printing some symbols and blinking dash goes left to right all the time (pretty fast)... I go back again to ATMega88 and everything works... Usart init and 2 functions that i used for communication .... void usart_init(void) { unsigned int USART_BAUDRATE = 9600; unsigned int ubrr = (((F_CPU / (USART_BAUDRATE * 16UL))) - 1); UBRR0H = (unsigned char)(ubrr>>8); UBRR0L = (unsigned char)ubrr; UCSR0B = (1<<RXEN0)|(1<<TXEN0); UCSR0C = (1<<USBS0)|(3<<UCSZ00); } void usart_transmit(uint8_t data) { while ( !( UCSR0A & (1<<UDRE0)) ); UDR0 = data; } uint8_t usart_receive( void ) { return UDR0; } Enable usart interrupt UCSR0B |= (1<<RXCIE0); ISR ISR(USART_RX_vect) { uint8_t W_buffer[8]; int i; for (i=0;i<8;i++) { W_buffer[i]=usart_receive(); usart_transmit(W_buffer[i]); } usart_transmit('#'); } I tried printing something at the beginning of the ISR to see if it goes inside but that never happens. Anyone have a idea what could be the issue here ? I feel i just go round and round in circles.... :( Quote Link to comment Share on other sites More sharing options...
Guest liquibyte Posted August 21, 2014 Report Share Posted August 21, 2014 Have you tried an AVR forum? I suspect the difference from working to not will be in the differences between the chips themselves. Quote Link to comment Share on other sites More sharing options...
