Guest bhuvaneshnick Posted August 26, 2014 Report Share Posted August 26, 2014 In the above circuit if clock(CLK 1) goes from 0 to 1 and input D =0 ,this makes Q=0.It is stated that when the clock is at HIGH(1) any further change in input does not affect output,how it is so .Can you explain me please.Thank you in advance Quote Link to comment Share on other sites More sharing options...
rameya Posted February 19, 2016 Report Share Posted February 19, 2016 Same confusion landed me here, but I wondered no answer till now. However I figured out the answer. @bhuvaneshnick I want to correct you that in D type Flip-Flop when Clock pulse is Low (not high) then there is no change in output. Look at the below Diagram, its clear if clock Pulse is low then the the output of first two NAND gates (A and B ) are 1, and output Q (and Q') doesn't changes its state as one of the input for NAND gates X and Y is 1. Means if the output Q is 1 then it remains 1 and if 0 then it remains 0.Check this Clap switch and find "Working of D-type Flip-flop" , It is in very simple language from where I got it. Also I strongly recommend you to learn about S-R Flip flop before D-type flip flop. Quote Link to comment Share on other sites More sharing options...
