Jump to content
Electronics-Lab.com Community
Sign in to follow this
Guest softmonaut
Need help to identify potentiometers, please
Guest softmonaut
I have to replace some scratchy potentiometers used as volume potentiometers in a Rocktron Velocity 300 guitar power amp from the early 1990's.
These parts are labeled
15A100K 9252 and
TØB10K 9303
Does someone have some informations about them or a source where I can get information?
THX, regards
Jörg
Share this post
Link to post
Share on other sites
Guest jhunax
I think the value are 100K and 10K. You can bring that potentiometers at the electronics shop near you.
Share this post
Link to post
Guest liquibyte
Not necessarily.  These are slide pots I believe.
http://www.tedss.com/2022001766
http://www.tedss.com/2022000119
Share this post
Link to post
Guest jhunax
I use "contact cleaner" to fix scratchy sounding pots. Sometimes a coupling capacitor leaks DC current into a pot that makes a scratchy sound that is fixed by replacing the capacitor.
lacquer thinner will be used too.
Share this post
Link to post
Lacquer thinner will probably dissolve plastic parts in a pot and deposit it as a mess all over the resistive track.
My contact cleaner is "safe on plastics, leaves behind zero residue and is fast drying". Why not use it?
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
