Jump to content
Electronics-Lab.com Community
Sign in to follow this
Guest KINGTIGER
Programmer
Guest KINGTIGER
hello everybody
im new in electronic specially microcontroller and in here :))))) so i start with a question
can i program ATMEGA8 WITH this programer? and how?
thanks
Share this post
Link to post
Share on other sites
Guest liquibyte
hello everybody
thanks
Have you tried reading the documentation where you got that project from?
Share this post
Link to post
Guest Electropepper
It looks like its for PICs, but like KINGTIGER says read more about where you got the schematics from, also that programmer looks rather old, its still using LPT, yucc  :P .
HERE  It includes schematic and firmware to build yourself.
Share this post
Link to post
I agree 100% with Electropepper.  Buy a commmercial programmer or build one from a kit.  You will find support in either case if you have questions.  The one shown looks old and who knows if it supports the chips you will eventually want to program.  Do you plan to use AVRStudio for writing and compling your programs?
Share this post
Link to post
Guest KINGTIGER
thanks everybody for reply and yes i read and its an old programmer but thougth i can program atmega8 with its ICSP connector cant i? i want a hi voltage programmer if anybody has made please help
Share this post
Link to post
KINGTIGER,  it appears that you don't want to use an Arduino (where only a usb cable is needed to program the chip) but rather have a ATMEGA8 in mind -perhaps because of a project you found uses one?  Or, you want to do direct programming.  Have you considered the 324u breakout boards from Adafruit. The 324u a broader capability than the Atmega8.  You only need a USB cable (no programming board) and Studio software to program using C.    It has a on board led that you can toggle to ensure your output timing is correct and you don't need to make a pcb to program it.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
