Guest KINGTIGER Posted October 19, 2014 Report Share Posted October 19, 2014 hello everybodyim new in electronic specially microcontroller and in here :))))) so i start with a questioncan i program ATMEGA8 WITH this programer? and how?thanks Quote Link to comment Share on other sites More sharing options...
Guest liquibyte Posted October 19, 2014 Report Share Posted October 19, 2014 hello everybodyim new in electronic specially microcontroller and in here :))))) so i start with a questioncan i program ATMEGA8 WITH this programer? and how?thanksHave you tried reading the documentation where you got that project from? Quote Link to comment Share on other sites More sharing options...
Guest Electropepper Posted October 20, 2014 Report Share Posted October 20, 2014 It looks like its for PICs, but like KINGTIGER says read more about where you got the schematics from, also that programmer looks rather old, its still using LPT, yucc :P .HERE It includes schematic and firmware to build yourself. Quote Link to comment Share on other sites More sharing options...
redwire Posted October 20, 2014 Report Share Posted October 20, 2014 I agree 100% with Electropepper. Buy a commmercial programmer or build one from a kit. You will find support in either case if you have questions. The one shown looks old and who knows if it supports the chips you will eventually want to program. Do you plan to use AVRStudio for writing and compling your programs? Quote Link to comment Share on other sites More sharing options...
Guest KINGTIGER Posted October 20, 2014 Report Share Posted October 20, 2014 thanks everybody for reply and yes i read and its an old programmer but thougth i can program atmega8 with its ICSP connector cant i? i want a hi voltage programmer if anybody has made please help Quote Link to comment Share on other sites More sharing options...
redwire Posted October 22, 2014 Report Share Posted October 22, 2014 KINGTIGER, it appears that you don't want to use an Arduino (where only a usb cable is needed to program the chip) but rather have a ATMEGA8 in mind -perhaps because of a project you found uses one? Or, you want to do direct programming. Have you considered the 324u breakout boards from Adafruit. The 324u a broader capability than the Atmega8. You only need a USB cable (no programming board) and Studio software to program using C. It has a on board led that you can toggle to ensure your output timing is correct and you don't need to make a pcb to program it. Quote Link to comment Share on other sites More sharing options...
