Jump to content
Electronics-Lab.com Community
Sign in to follow this
flippityflop
are BT2222 transistors the same as 2N2222
are these NPN BJTs:
http://pdf1.alldatasheet.com/datasheet-pdf/view/17918/PHILIPS/MMBT2222A.html
the same as those 2N2222 that has been around for since forever? can i trust that the reverse active and avalanche breakdown profiles are the same??
Share this post
Link to post
Share on other sites
A transistor is slowly damaged when operating with avalanche breakdown of a reverse-biased emitter-base junction.
The 2N2222 and BT2222 are guaranteed to withstand a reverse emitter-base voltage of 6V or less.
Both transistors probably have the same chip but since the BT2222 is in a tiny case then it will overheat even with a very low power dissipation.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
