Jump to content
Electronics-Lab.com Community
Sign in to follow this
chiara
Humidity sensor
According to Sensirion datasheet here SHT31-ARP-B is an analog output temperature and humidity sensor with linearized and calibrated output. To interface it with Arduino you will have to measure the output voltage using an Arduino analog input and then convert the reading to humidity or temperature value based on the linear formulas found on the datasheet. These formulas are depended on the supply voltage of the sensor.
I also found an Arduino library for this sensor here: https://github.com/winkj/arduino-sht you may find it useful.
Edited by admin
Share this post
Link to post
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
