Jump to content
Electronics-Lab.com Community
Sign in to follow this
Alex Vincent
proteus 8
when you enter you go to new project then you go to name and write the name of your project then click on next ,select create a schematic from the selected template then you choose one, "me i prefer the default one "then you click on next .the same thing you choose  create a PCB layout from the selected template then next and finally finish .after that you select me i work with ISIS so as you like you select one of them.then you go to library then pick parts from library and you write in the keywords what component you want," for example resistors" you click on resistors written in the category icon then you go to sub-category you choose one, and finally you chosse from results what you need and you click on ok and now your components are ready for using .if you have any problem i'm here to help you.
Share this post
Link to post
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
