Barbra
how to make a mailbox light? guys
5 posts in this topic
I want to charge a LiPo battery via the ballance plugs. So it's a ballanced charge, and I don't run into any problems, day in and day out.
The light can be very small, but I want it to be bright. So even using a couple LEDs would make a really nice and bright mailbox light.
I want the light to last all night long. So that means I need to know the current draw of the LEDs to the capacity of the LiPo batteries.
etc.
I need help on this. I need help with the fact how to use an Op Amp to shut the light off when it's daylight out.. or a specific amount of light is sensed.
Light Sensed : Start charging, and turn off the LED lights.
Light Sensed : Set the Op Amp to detect 4.2vdc. When it does, shut down the charging, &
LED's stay off until darkness is detected.
That's my idea of a mailbox light, with very long battery life, and high current solar charging abilities.
Can anyone help me with this kind of circuit?
Here is where my LED come from http://www.kynix.com/Search/led.html
Share this post
Link to post
Share on other sites
Drill a hole on top of the mailbox and insert a ----> 0075623374123_500X500.jpg
Without its pole.  Optional, add a door switch for the LED.  Done fast for $1.  Some silicone sealant may help.
Barbra likes this
Share this post
Link to post
The cheap Chinese solar garden light has a dim light for only a couple of hours following a sunny day. It lasts only a couple of months before its LED, solar panel and battery rust away. No light following a cloudy day. The cheap solar panel actually gets sunburned.
Use the pcb circuit from a solar garden light and amplify its output with a transistor to drive a bright high current LED. Use a larger high current high quality solar panel and battery. Properly seal everything to prevent rust.
Share this post
Link to post
yaaas, many chinese solar garden light do have a dim light and last not long.    And i will try your way to make a brighter led, thanks man.
could really be helpful, though my eyes were indeed caught by you Gif-avatar,  hahaha
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
