Sign in to follow this
lidas
design a LED driver circuit
I am looking for someone capable of progettarmi a circuit that led to a 28 / 30v feed me from a 12-volt power to the LEDs to function also needs 1.5 / 3 Ah
I have to feed this led
http://www.digikey.it/product-detail/it/bridgelux/BXRC-40A4001-F-03/976-1235-ND/5048136
I wish the circuit has the ability to vary the volts in output and also the amps and that can dim the LED
100%
60%
30%
can you help me
Share this post
Link to post
Share on other sites
31W a lot of power in the small area so the LED will get extremely hot. How will you cool it? A number of lower power LEDs will be easier to cool.
An LED sets its own voltage that you cannot adjust. Its current sets its brightness.
Share this post
Link to post
That's not easy. I mean, the schematic is not a big deal, but 90% efficiency at those high voltages are not easy to obtain. Since your output voltage is between the input range, you can't use a pure boost or buck topology. But your best bet is to use a dedicated IC, for example from Linear. 90% is achieved only in the best condition, and mostly for inputs > 10V.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
