Sign in to follow this
jackadam
Charging 6 volt battery with a 12 volt charger and small lightbulb
Connect a 12 volt taillight, turn signal or any small 12 volt lightbulb to your 6 volt battery. Now connect a 12 volt charger to the 6 volt battery. Voltage at battery will be 6.7 to 7.02 volts. Unscrew the three caps on the 6 volt battery and observe the bubbles of hydrogen gas leaving the electrolyte from each cell. The cell on the + side will stop bubbling first as the 6 volt battery reaches full charge, then the middle cell will stop bubbling, then the cell on the -- side will just barely be bubbling when fully charged. The small light creates a drain and the charger continues to charge that cell.
more: xe 2 tan hyundai
A 12 volt battery connected to a 12 volt charger will cut out at 14.6 volts. Then the 12 volt battery will settle to 12.7 volts after 30 minutes.
A 6 volt battery connected to a 12 volt charger with the small 12volt light WILL NOT cut out because you want a fully charged 6 volt battery to settle to 6.4 volts.
You must observe and manually disconnect the charger.
more: giá fortuner 2017
Do not connect the small lightbulb in series because the 12volt charger will sense too much resistance and then indicate a fault after two minutes.
Share this post
Link to post
Share on other sites
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
