Sign in to follow this
jackadam
Charging Li-Ion while providing load.
Hello. I'm building a 12v bluetooth speaker and am trying to design the battery and charging system. I'm thinking about using 3 of the Panosonic NCR18650B in series to start, and then perhaps upgrade to another 3 pack in parallel later if the battery life isn't good enough. This is my first experience building something with Lithium batteries and it's a bit intimidating. I've done quite a bit of reading, but i wanted to come here and ask a few questions in hopes of getting this right the 1st try.
more: eco dream city
The BMS i've chosen shows "charge/discharge" on one of the images for the P+ and P- terminals. I'm hoping this means that I can connect my incoming power AND my load (12v amp & bluetooth module) to those terminals and it will allow me to use the amp while charging. In the description it says "Charge with 12.6-13.0V Power supply (not included)." With that in mind, here are my questions:
1) I was working under the assumption that i would need a battery charger or charging circuit before the BMS, but the description makes it sound like i can just put a power supply directly to the BMS. Would one of the 12.6v li-ion plug-in style chargers (like this one) be ok to use with this BMS? Would a charger like that cause interference noise in the speaker?
more: dự án mỹ đình plaza 2
2) When connecting the power and load to the BMS, do i need any kind of diode in line with the load?
3) I was planning to get the protected versions of these batteries, but is that necessary if i use the BMS and charger that also offers protection? If I was to use the protected batteries, does that eliminate the need for the BMS?
I have built NiMH chargers using the Maxim ICs in the past that allow for charging and load as the same time without any interference, and I know that option is available for Li-Ion as well. However, i would REALLY like to avoid making my own charger if possible.
more: dự án eco dream
Thanks for any advice you can offer!
Share this post
Link to post
Share on other sites
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
