Jump to content
Electronics-Lab.com Community
In this project, a complete design and development procedure of a digital thermometer has been discussed. The algorithm used in this design is simple and easy to understand. The components used are limited and readily available in the market. Although the overall development of this project is lowcost and easy still the results are extraordinary. Let’s see how this design works.
Arduino and LM35 based digital thermometers can be developed at home with very few components and instruments needed. Arduino UNO used in this design is a microcontroller which is responsible for data handling and processing for temperature calculation and display. Arduino UNO has digital I/O and Analog pins. In this case, we are using both.
The next component is LM35 which is a temperature sensor and looks more like a simple BJT. LM35 is cheap as compared to most of the temperature sensors and yet offers a high level of accuracy even at extreme temperatures. LM35 can be used in both analog circuits and embedded systems since it offers analog voltages at the output.
The circuit diagram described in this simulation video is simple and can be easily modified if needed.  Click For Full Project Detail
Simulation Video
 Testing Video
Click for Coding and full project detail
Share this post
Link to post
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
Sign in to follow this
  • Create New...
