Jump to content
Electronics-Lab.com Community
Stockleys
12v 3000w inverter repair help
Hi all.
First time post for me
I’m after some help
I am trying to repair a high frequency 3000w inverter.
It worked great for 3 weeks when I got it (after replacing 2 IGBT’s)
But then they blew and many more replacements
I bought a new spwm board from the manufacturer and a complete new set of IGBT’s along with their associated resistors and diode.
Installed. And nothing. ABout 10 seconds in and one of the h bridge drivers exploded.
So I ordered an EGS002 board from amazon. All pinouts exactly the same. Same chips as the spwm from the manufacturer only a third the price.
I have installed this and tested all components around it including the IGBT’s. They are all good.
The IGBT’s are getting a steady 390vdc source.
The spwm getting a steady 5v and 12v
But I can’t get an output. I can hear the transformers buzz for 3 seconds then stop I get a blip of up to 8vac at the output.
The spwm board flashes out the code for under voltage and over voltage.
Where do I go from here? I don’t own a scope. Only a ddm.
I have checked and re check all components and solder joints.  But as I don’t own a scope, I can’t think what else to do.
Thanks in advance
Share this post
Link to post
Share on other sites
Without a circuit diagram it is very difficult to help you.  You can find numerous videos on youtube.com related to "EGS002 "   that maybe helpful. Good luck.
Looks like I was born under the sign  -V  (I talk to much?)
Share this post
Link to post
I got myself a usb scope.
I found that the egs002 wasn’t giving the correct wave.  On outputs 1 and 2.   And output 3 was a constant 6v.  Not a wave at all.    Got another egs002 (before getting the scope). And that had one dead output.
Attatched is a schematic for the egs002.   And the h bridge.  Which although not for my inverter, is identical
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
