Linksprite-Yuki Posted August 22, 2016 Report Share Posted August 22, 2016 Summary DHT22 module applies specific digital blocks collection technology and temperature and humidity sensing technology to ensure that products with high reliability and excellent long-term stability. Sensor comprises a capacitive humidity sensing element and a high-precision temperature component, and with a high-performance 8-bit microcontroller connected. Therefore, the product has excellent quality, fast response, anti-interference ability, high cost and so on. Measurable temperature range of the module: -40-80 ℃ ± 0.5 ℃, humidity range: 20-90% RH ± 2% RH. The module is widely used in temperature and humidity regulator, weather station, and other relevant temperature and humidity detection control. Material preparation LinkNode D1 x 1 DHT22 x 1 DuPont line Arduino IDE Steps 1. Login linksprite.io ,record the “Device ID” and “API key” ( If there is no account, please sign up. ) 1. My Profile -> API key 2. My device->Create DIY Device Enter Device Name,Device Type , Group Name , the device number is 03, device name and device grouping can be any. Note: Device Type must be selected 03(Custom device type) . Click the device you created and record the “Device ID”. 2. Edit and run the code Modify the “apikey” and “deviceID” with content acquired before Compile the code and upload. 3. Results Serial Monitor 2. LinkSprite IO Quote Link to comment Share on other sites More sharing options...
