![LIS2DTW12 – Temperature sensor combined with a 3-axis MEMS accelerometer LIS2DTW12 – Temperature sensor combined with a 3-axis MEMS accelerometer](https://www.electronics-lab.com/wp-content/uploads/2019/05/N4149D-Apr-23-2019-LIS2DTW12-MEMS-sensor_IMAGE.jpg)
The LIS2DTW12 is an ultra-low-power high-performance three-axis linear accelerometer and temperature sensor belonging to the “femto” family which leverages on the robust and mature manufacturing processes already used for the production of micromachined accelerometers.
- The device has user-selectable full scales of ±2g/±4g/±8g/±16g and is capable of measuring accelerations with output data rates from 1.6 Hz to 1600 Hz.
- The LIS2DTW12 has an embedded 0.8 °C (typ. accuracy) temperature sensor with ODRs ranging from 50 to 1.6 Hz and resolution from 8 to 12 bits.
- The LIS2DTW12 has an integrated 32-level first-in, first-out (FIFO) buffer allowing the user to store data in order to limit intervention by the host processor.
- The embedded self-test capability allows the user to check the functioning of the sensor in the final application.
- The device has a dedicated internal engine to process motion and acceleration detection including free-fall, wakeup, highly configurable single/double-tap recognition, activity/inactivity, stationary/motion detection, portrait/landscape detection and 6D/4D orientation.
- The LIS2DTW12 is available in a small thin plastic land grid array package (LGA) and it is guaranteed to operate over an extended temperature range from -40 °C to +85 °C.
Key Features
- Ultra-low power consumption: 50 nA in power-down mode, below 1 µA in active low-power mode
- Very low noise: down to 1.3 mg RMS in low-power mode
- 0.8 °C (typ. accuracy) embedded temperature sensor
- Multiple operating modes with multiple bandwidths
- Android stationary detection, motion detection
- Supply voltage, 1.62 V to 3.6 V
- Independent IO supply
- ±2g/±4g/±8g/±16g full scale
- High-speed I²C/SPI digital output interface
- Single data conversion on demand
- 16-bit accelerometer data output
- 12-bit temperature data output
- Self-test
- 32-level FIFO
- 10000 g high shock survivability
- ECOPACK, RoHS and “Green” compliant
more information and samples ordering on www.st.com
Login
