15A 100V Isolated Half-Bridge Driver
  • Rajkumar Sharma
  • 8.922 Views
  • moderate
  • Tested
  • SKU: EL82131
  • Quote Now
15 A 100V Isolated Half bridge driver project intended to be used for DC-DC converters, inverters, LED driver and motor driver applications. This projects is really helpful in industrial applications where noise is a concern since project provides optical isolation between microcontroller and high current output. ADuM4224 isolated precision Half-Bridge driver is the heart of the project. IRFR120 dual Mosfet is used as output driver. MOSFET can be replaced as per application requirement of voltage and current rating. The ADuM4224 isolators each provide two independent isolated channels. They operate with an input supply voltage ranging from 3.0 V to 5.5 V, providing compatibility with lower voltage systems. In comparison to gate drivers employing high voltage level translation methodologies, the project offers the benefit of true, galvanic isolation between the input and each output. Each output can be continuously operated up to 537 V peak relative to the input, thereby supporting low-side switching to negative voltages. The differential voltage between the high-side and low-side can be as high as 800 V peak. Refer to truth table for operation conditions. The board tested with input frequency of 100 KHz but will support frequency up to 1 MHz. CN3 connector provided for logic signal and supply input, CN1 Output drive supply , CN2 load supply input, CN4 for load connection.
The ADuM42241 is 4 A isolated, half-bridge gate driver that employ the Analog Devices, Inc., iCoupler® technology to provide independent and isolated high-side and low-side outputs. The ADuM4224 provides 5000 V rms isolation in the wide-body, 16-lead SOIC package. Combining high speed CMOS and monolithic transformer technology, these isolation components provide outstanding performance characteristics superior to the alternatives, such as the combination of pulse transformers and gate drivers.
Note : Output MOSFETs can be used as per application requirement of voltage and load current, supply input will be depend on MOSFET.
  • Supply Output Side 12V DC ( 5V-18V Possible Refer Note)
  • Supply VDD1 5V-12V DC
  • Input Signal VIA/VIB 3V to 5V
  • Frequency Up to 1Mhz
  • PCB Dimensions 57.04mm X 48.12 mm
Schematic
Parts List
Connections
ADuM4224 Truth Table
Photos
ADuM4224 Datasheet
PCB
2 Comments
Donald Livesay
Hey dude where is the motor BEMF Diodes?. other then that nice board.
RELATED PROJECTS
TOP PCB Companies
