16 Channel InfraRed remote controller – RC5 Philips Code
- Rajkumar Sharma
- 19.719 Views
- moderate
- Tested
- SKU: EL49625
- Quote Now
16 Channel Infra-Red remote controller is based on PIC16F73 Microcontroller from Microchip. The receiver part follows RC5 (Philips) Code Format. Tiny receiver provides 16 latch outputs or 8 Latch + 8 Momentary outputs by closing Jumper J1. All outputs are TTL and can drive Relay board or solid state relay. The circuit uses TSOP1738 Infra-Red receiver module which provides high degree of noise immunity against interfering light source.
For NEC Code check this project: 16 Channel Tiny InfraRed Remote Controller – NEC Code
The remote used to test the board is “Philips 90CH” from www.lripl.com
- Supply Remote Transmitter RC5 Philips 2 x AAA Battery
- Supply Receiver 7V to 12V DC
- Modulation 38Khz
- Philips RC5 Code Format
- Operating range up to 20 feet
- 2 Pin Screw Terminals for Supply Input
- On Board Power LED
- Onboard VT (Valid Transmission) LED
- All Outputs TTL Level provided with Header Connector
- Jumper (J1) for Mode Selection
- J1 Open 16 Latch Outputs (or 16 Momentary Outputs – depending on .hex)
- J1 Closed 8Latch + 8 Momentary
- PCB dimensions: 69.77 x 26.83 mm
Application
- Robotics
- Lights
- Fans
- Home Appliances
- Remote Door closer
- Remote Curtains
- Security Systems
Schematic
Parts List
Photos
Video
I want to purchase
check on http://www.koteq.com for kits of our projects.
where is c code .
Hi,Can you write program for me
Where might I be able to buy the programmed boards and the remotes? I am in Canada.
Please check on koteq.com for kits
I want to purchase, where I can get it in india Kolkata City
How many boards do you need?
I need 2pcs board. What will be the price if it comes with more channel like 24
Check your email, please.
