4 channel infrared remote relays
- Rajkumar Sharma
- 83.803 Views
- medium
- Tested
- SKU: EL36876
- Quote Now
Description
4 Channel Infrared (IR) Remote controller is using HT12A and HT12D encoder / decoder chips from Holtek.
- Supply – Transmitter : 3 to 5 VDC, 5 V @ 20 mA & Receiver : 5 VDC @ 200 mA
- Output : 4 channel Latch or Momentary on board Jumper for selection
- Crystal based oscillator for reliability of operation
- Jumper selectable 8 bit address code
- LED output to indicate reception
- On/Off slide switch in the transmitter
- Power-On LED indicator in the Receiver / Transmitter
- Valid transmission indicator
- 4 LED for Relay On/Off status
- Four mounting holes of 3.2 mm each
- PCB dimensions – Transmitter : 43 mm x 56 mm & Receiver : 80 mm x 73 mm
Schematic
Parts List
Receiver BOM
app appRequired PCB design. If possible please send .it will be easy for me to make pcb.
9213745590 whats
New Delhi
Do you need Gerber files ?
