AC Solid State Relay
  • Rajkumar Sharma
  • 21.500 Views
  • moderate
  • Tested
  • SKU: EL46918
  • Quote Now
Solid_State_Relay_IMG2
This simple circuit designed around Solid State Relay S216S02 from SHARP. The S216S02 solid State Relay (SSR) is an integration of an infrared emitting diode (IRED), a Phototraic Detector and a main output Traic. These devices are ideally suited for controlling high voltage AC loads with solid state reliability while providing 4KV isolation from input to output.
A solid-state relay (SSR) is an electronic switching device that switches on or off when a small external voltage is applied across its control terminals. SSRs consist of a opto-isolator  which responds to an appropriate input (control signal), a solid-state electronic switching device which switches power to the load circuitry, and a coupling mechanism to enable the control signal to activate this switch without mechanical parts. This relay designed to switch either AC load up-to 1KW. It serves the same function as an electromechanical relay, but has no moving parts. Solid-state relays have fast switching speeds compared with electromechanical relays, and have no physical contacts to wear out.
  • AC Load Upto 16Amps Peak
  • Maximum Supply input 600V AC
  • TTL Input Trigger Voltage across Anode and Cathode 3 to 6V @ 20mA
  • Input Trigger Voltage across Transistor Base 1.5V to 24V DC 5mA
  • Small PCB with on Board Snubber Circuit for inductive Load
Schematic
Solid_State_Relay_SCH
Parts List
Solid_State_Relay_BOM
Photos
Solid_State_Relay_IMG1
Solid_State_Relay_IMG3
Video
PCB
1 Comment
Suresh
The Sharp Ssr mentioned is obsolete now. What alternate can I use
RELATED PROJECTS
TOP PCB Companies
