DC servo motor driver
- Rajkumar Sharma
- 24.615 Views
- moderate
- Tested
- SKU: EL34567
- Quote Now
Description
DC Servo Motor Driver kit, designed using MC33030 IC, is the fastest and low cost way of getting your DC Servo Motor up and running.
- Input – 12 VDC
- Output – can drive upto 1 A Load
- Overcurrent shutdown, overvoltage shutdown
- Programmable reference input
- Power-On LED indicator
- Relimate connector for interfacing the kit
- Four mounting holes of 3.2 mm each
- PCB dimensions 45 mm x 54 mm
Schematic
Parts
Looking for circuit (1/2 amp tops) that can reverse its polarity every 3 minutes.
