RF Remote DC Motor Direction Controller
  • Rajkumar Sharma
  • 26.942 Views
  • moderate
  • Tested
  • SKU: EL45493
  • Quote Now
H003
RF Based DC Motor Direction Controller project provides an easy way to control the direction of your DC Motor connected to the receiver.  This project has been design around HT12E and HT12D encoder / decoder chips from Holtek.  With jumper selectable address on the receiver and transmitter we can control multiple   motors in one area without interference with one remote.
Application
  • Remote Motorized Volume Control
  • Remote Toy or Robot Controller
  • Remote Controlled Curtains
  • Supply input, Transmitter : 3 ~ 5 VDC, 5 V @ 20 mA & Receiver : 5 V @ 31 mA without Motor
  • Motor current and supply: 5 ~ 6 VDC @ 500 mA
  • Range up to 30Mtrs, open area it can be more
  • Jumper connector selectable 8 bit address code
  • Valid Transmission LED
  • On Board On/OFF Slide Switch for Transmitter
  • Power-On LED indicator in the receiver/transmitter
  • High noise immunity
  • Screw terminal connector and terminal pins for easy input/output connection
  • Four mounting holes of 3.2 mm each
  • PCB dimensions, Transmitter : 60 mm x 37 mm & Receiver : 60 mm x 58 mm
Schematic
RF REMOTE MOTOR DRIVER TX SCH
RF REMOTE MOTOR DRIVER RX SCHpsd
Parts List
DECODER BOM
ENCODER BOM
PCB
1 Comment
Raghu
Super duper excellent sir raghu
RELATED PROJECTS
TOP PCB Companies
