Using the ST7735 1.8″ Color TFT Display with Arduino
- Nick Koumaris
- http://educ8s.tv/
- info@educ8s.tv
- 106.310 Views
- moderate
- Tested
Hi guys, welcome to today’s tutorial. Today, we will look on how to use the 1.8″ ST7735Â colored TFT display with Arduino. The past few tutorials have been focused on how to use the Nokia 5110 LCD display extensively but there will be a time when we will need to use a colored display or something bigger with additional features, that’s where the 1.8″ ST7735 TFT display comes in.
The ST7735 TFT display is a 1.8″ display with a resolution of 128×160 pixels and can display a wide range of colors ( full 18-bit color, 262,144 shades!). The display uses the SPI protocol for communication and has its own pixel-addressable frame buffer which means it can be used with all kinds of microcontroller and you only need 4 i/o pins. To complement the display, it also comes with an SD card slot on which colored bitmaps can be loaded and easily displayed on the screen.
Other features of the display include:
- 1.8″ diagonal LCD TFT display
- 128×160 resolution, 18-bit (262,144) color
- 4 or 5 wire SPI digital interface
- Built-in microSD slot – uses 2 more digital lines
- 5V compatible! Use with 3.3V or 5V logic
- Onboard 3.3V @ 150mA LDO regulator
- 2 white LED backlight, a transistor connected so you can PWM dim the backlight
- 1×10 header for easy breadboarding
- 4 x 0.9″/2mm mounting holes in corners
- Overall dimensions: 1.35″ x 2.2″ x 0.25″ (34mm x 56mm x 6.5mm)
- Current draw is based on LED backlight usage: with full backlight draw is ~50mA
The goal of this tutorial is to demonstrate the abilities of the TFT to display images and text in different colors and some animation.
Required Components
The following components are needed for this tutorial:
As usual, the exact components used for this tutorial can be bought by following the link attached to each of the components above.
Schematics
The schematics for this project is fairly easy as the only thing we will be connecting to the Arduino is the display. Connect the display to the Arduino as shown in the schematics below.
Due to variation in display pin out from different manufacturers and for clarity, the pin connection between the Arduino and the TFT display is mapped out below:
1.8″ TFT – Arduino
LED - 3.3v SCK - D13 SDA - D11 DC - D9 Reset - D8 CS - D10 GND - GND VCC - 5v
Double check the connection to be sure everything is as it should be. All good? now we can proceed to the code.
Code
We will use two libraries from Adafruit to help us easily communicate with the LCD. The libraries include the Adafruit GFX library which can be downloaded here and the Adafruit ST7735 Library which can be downloaded here.
We will use two example sketches to demonstrate the use of the ST7735 TFT display. The first example is the lightweight TFT Display text example sketch from the Adafruit TFT examples. It can be accessed by going to examples -> TFT -> Arduino -> TFTDisplaytext. This example displays the analog value of pin A0 on the display. It is one of the easiest examples that can be used to demonstrate the ability of this display.
The second example is the graphics test example from the more capable and heavier Adafruit ST7735 Arduino library. I will explain this particular example as it features the use of the display for diverse purposes including the display of text and “animated” graphics. With the Adafruit ST7735 library installed, this example can be accessed by going to examples -> Adafruit ST7735 library -> graphics test.
To briefly explain the example,
The first thing, as usual, is to include the libraries to be used after which we declare the pins on the Arduino to which our LCD pins are connected to. We also make a slight change to the code setting reset pin as pin 8 and DC pin as pin 9 to match our schematics.
#include <Adafruit_GFX.h> // Core graphics library #include <Adafruit_ST7735.h> // Hardware-specific library #include <SPI.h> // For the breakout, you can use any 2 or 3 pins // These pins will also work for the 1.8" TFT shield #define TFT_CS 10 #define TFT_RST 8 // you can also connect this to the Arduino reset // in which case, set this #define pin to 0! #define TFT_DC 9
Next, we create an object of the library with the pins to which the LCD is connected on the Arduino as parameters. There are two options for this, feel free to choose the most preferred.
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST); // Option 2: use any pins but a little slower! #define TFT_SCLK 13 // set these to be whatever pins you like! #define TFT_MOSI 11 // set these to be whatever pins you like! //Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
Next, we move to the void setup function where we initialize the screen and call different test functions to display certain texts or images. These functions can be edited to display what you want based on your project needs.
void setup(void) { Serial.begin(9600); Serial.print("Hello! ST7735 TFT Test"); // Use this initializer if you're using a 1.8" TFT tft.initR(INITR_BLACKTAB); // initialize a ST7735S chip, black tab // Use this initializer (uncomment) if you're using a 1.44" TFT //tft.initR(INITR_144GREENTAB); // initialize a ST7735S chip, black tab Serial.println("Initialized"); uint16_t time = millis(); tft.fillScreen(ST7735_BLACK); time = millis() - time; Serial.println(time, DEC); delay(500); // large block of text tft.fillScreen(ST7735_BLACK); testdrawtext("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa, fringilla sed malesuada et, malesuada sit amet turpis. Sed porttitor neque ut ante pretium vitae malesuada nunc bibendum. Nullam aliquet ultrices massa eu hendrerit. Ut sed nisi lorem. In vestibulum purus a tortor imperdiet posuere. ", ST7735_WHITE); delay(1000); // tft print function! tftPrintTest(); delay(4000); // a single pixel tft.drawPixel(tft.width()/2, tft.height()/2, ST7735_GREEN); delay(500); // line draw test testlines(ST7735_YELLOW); delay(500); // optimized lines testfastlines(ST7735_RED, ST7735_BLUE); delay(500); testdrawrects(ST7735_GREEN); delay(500); testfillrects(ST7735_YELLOW, ST7735_MAGENTA); delay(500); tft.fillScreen(ST7735_BLACK); testfillcircles(10, ST7735_BLUE); testdrawcircles(10, ST7735_WHITE); delay(500); testroundrects(); delay(500); testtriangles(); delay(500); mediabuttons(); delay(500); Serial.println("done"); delay(1000); }
Next, is the void loop function. The void loop function for this project basically inverts the display after 500 ms.
void loop() { tft.invertDisplay(true); delay(500); tft.invertDisplay(false); delay(500); }
All the functions called under the void setup function, perform different functions, some draw lines, some, boxes and text with different font, color and size and they can all be edited to do what your project needs.
The complete code for this is available under the libraries example on the Arduino IDE. Don’t forget to change the DC and the RESET pin configuration in the code to match the schematics.
Demo
Uploading the code to the Arduino board brings a flash of different shapes and text with different colors on the display. I captured one and its shown in the image below.
Cool right?
That’s it for this tutorial guys, what interesting thing are you going to build with this display? Let’s get the conversation started. Feel free to reach me via the comment section if you have any questions as regards this project.
Till next time!
You can watch the video of this tutorial on youtube here.
Thanks to you for sharing this valuable article
Thanks for this tutorial. I’m going to do 2 projects with this. A LPG gas detector and readout, and a display for various sensors including temp, humidity.
..wiring the picture is wrong
the voltage pins are reversed
Thats the lamest answer EVER!!!
@JoJo, this is a very good comment from @Kiker, the black and red wires actually are mixed up in the drawing so GND on UNO goes to VCC on TFT and the other way around.
He’s right you know Pin1 GND Pin2 Vcc
When I try to compile I get
‘testdrawtext’ was not declared in this scope
I have downloaded and installed the Adafruit libraries from GitHub
Not usable for beginner. ‘Testdrawtext’ was not declared in this scope. I don’t know how to fix it. End of project…my first project with a display….
Watch the video. Or see the full code here https://github.com/adafruit/Adafruit-ST7735-Library/blob/master/examples/graphicstest_hallowing_m4/graphicstest_hallowing_m4.ino . Not sure why this isnt included in the text version.
Do not copy the code from the text in the artical, you will indeed get a compile error that Testdrawtext was not declared.
Basically its a subroutine wich was not included in the code on the artical.
Just get the example code from the examples in the Arduino, it called graphics test.
Also make sure pin 8 and 9 are wrong in the original code, it should look like this.
#define TFT_CS 10 //OK
#define TFT_RST 8 // listed in program as 9
#define TFT_DC 9 // listed in program as 8
// wrong in original code
// #define TFT_CS 10
// #define TFT_RST 9 // Or set to -1 and connect to Arduino RESET pin
// #define TFT_DC 8
If you wire the display correct to an Arduino Uno it should work.
Please note that in some specs they mention Vcc should be 3.3V but that does not work, use 5V.
Also confusing that some display have a LED pin or a BLK pin, this pin is for the brightness of the display, connect 3.3V to it.
You can also connect a potmeter to adjust the brightness if you like.
Hello, I have a question, Can I connect this display in another way? Because I need one PWM pin in arduino, (anothers are busy) For example I tried connect SDA pin on display to SDA pin on arduino, but this not worked, mayby somewhere i must “write” this to “display” that I don’t use pin D11 on arduino but SDA pin.
You will have to change the code if you use other pin for the display.
Mike thanks for responding
I changed my code for this:
#define TFT_CS 10
#define TFT_RST -1 // in example form adafruit was write that we can put -1 here and pin reset from display put to reset pin in arduino
#define TFT_DC 8
#define x_mid 79
#define y_mid 127
#define R 70
And this not working, screen is always white.
Before changes my code looked like this:
#define TFT_CS 10
#define TFT_RST 8
#define TFT_DC 9
#define x_mid 79
#define y_mid 127
#define R 70
and this working fine but i need PIN 9 because have PWM modulation.
I am not an expert in code, but i think you should definitely check the Adafruit library readme. Any chance you use another PWM pin?
Ok nevermind, I recovered one PWM pin, I used it to HC-SR04 sensor for echo pin, but I also can use a normal pin for echo, thanks for help ;).
Hello this is nice and all, but how u do a video loop on the onboard SD card?
Video is gone.
Hi guys, It works fine for me after 3 hours of trying an testing and applying logic and common sense. I detected an error in the graphicstest CODE:
Took me a while to figure out, but these CORRECTED definitions match the wiring diagram and the pin description. For a beginner this can be a large NO NO.
It was a major task on my part but I did get my TFT 1.8″ working with Leonardo. Now, I need to learn how to rotate the display to “landscape.” Can you help me. I am new to Arduino so hang in there with me. I am running IDE 2.1.1, Win 10 on desktop. The TFT is fm China with ST7735S. This TFT is without the SD card slot and has only 8 connections. Dan
There’s a rotate function in the Adafruit library, I have 3 displays working on one system, all landscape.
tft1.setRotation(3); spins tft1 270 degrees. 1=90, 2=180
how do you display images on this?
He already said: easily! 🙂
Hi Bruder, a nice project, i liked it. But how can i Display on the TFT ST7735 e.g. Turkish characters, Like Äž, Åž, Ç, Ö,…?
Many thanks in advance. Ercan from Germany
