![+/- 1.7g Dual-Axis IMEMS Accelerometer Using ADXL203 +/- 1.7g Dual-Axis IMEMS Accelerometer Using ADXL203](https://www.electronics-lab.com/wp-content/uploads/2016/12/ADXL203-board-IMG1.jpg)
The ADXL203 Module is high precision, low power, complete dual-axis accelerometers with signal conditioned voltage outputs, all on a single, monolithic IC. The ADXL203 measure acceleration with a full-scale range of ±1.7 g, ±5 g, or ±18 g. The ADXL203 can measure both dynamic acceleration (for example, vibration) and static acceleration (for example, gravity).The typical noise floor is 110 μg/√Hz, allowing signals below 1 mg (0.06° of inclination) to be resolved in tilt sensing applications using narrow bandwidths (<60 Hz).The user selects the bandwidth of the accelerometer using Capacitor CX and Capacitor CY at the XOUT and YOUT pins. Bandwidths of 0.5 Hz to 2.5 kHz can be selected to suit the application.
+/- 1.7g Dual-Axis IMEMS Accelerometer Using ADXL203 – [Link]
