![110V/220V Electric Mini Circular Saw For Household Use 110V/220V Electric Mini Circular Saw For Household Use](https://www.electronics-lab.com/wp-content/uploads/2021/01/02105290-scaled.jpg)
There are many Mini Circular Saws available in the market, and it might be confusing getting one appropriate for you. I recently stumbled upon one of such saws, a 110V/220V Electric Mini Circular Saw. The circular saw is suitable for making straight cuts in wood, wood-like material, aluminum, plastic, and steel that has not undergone heat treatment. However, this saw should not be used to cut materials containing asbestos. This saw is designed for household use and should only be used for such purposes.
The mini circular saw has a portable design, easy to carry, store, and features good portability and easy operation. It features a comfortable rubbery handle, which is very durable, and the rubber handle is easy to hold and operate. The mini circular saw is equipped with three cutting blades, and these 3 blades are for different materials, helping you to meet your different requirements. It is easy to operate thanks to the rear motor separating the saw at the center of gravity to suit your hand when in use. The mini circular saw is equipped with an adjustable cutting depth bar to adjust the depth, the maximum depth is 12mmm. One of the benefits of the mini circular saw is that it is lightweight, well-balanced, and a good alternative to bulkier circular saws to perform precise cuts in tight areas that larger options just can’t accomplish. The mini circular saw features air vents for heat dissipation, which help to keep the saw cool and prolong the life of the saw.
Specifications:
- Material – Metal
- Color – Black + Red
- Vacuum Hose Length – About 1.68m
- No-load Speed – 8200rpm
- Plug Type – US Plug 110V, EU Plug 220V
- Sawing Depth – About 0-12mm
The lightweight electric-powered mini saw utilizes a flat, round blade to cut a variety of materials- generally metal, plastic, wood, and even stone (with a diamond cutting edge). The mini circular saw is ideal for one-handed use. The manufacturer utilizes ergonomic handles with on/off triggers the switch and metal/plastic guards to ensure the saw-operator doesn’t accidentally come in contact with the spinning blade. The circular saw also features height, depth & bevel adjustments for enhanced precision. For wood-cuts, the circular saw blades are designed to produce cross-cuts, rip-cuts, or a combination of the two. The vacuum port of the mini circular saw as an added feature is helpful because it minimizes the mess when working indoors. The noise and vibration levels were calculated in accordance with standard EN 60745. The total vibration values (sum of vectors in three directions) were determined in accordance with standard EN 60745.
Notes:
- Please allow 1-3 cm error due to manual measurement.
- Everyone has different screens, so item color displayed in photos may be showing slightly different from the real object. Please take the real one as standard.
Package List:
- 1 x Mini Electric Saw
- 1 x Vacuum Tube
- 2 x Hex Wrench
- 1 x Wood Saw Cutting Blade
- 1 x Marble Blade
- 1 x High-Speed Steel Cutting Blade
The mini circular saw is available on Banggood for $79.99.
