![12V NE555 PWM Controller 12V NE555 PWM Controller](https://www.electronics-lab.com/wp-content/uploads/2016/08/FBL1YSEISCAQG0A.MEDIUM.jpg)
Motor Speed Controller, LED Dimmer, Heat controller, voltage controller for an electrolytic etcher etc.
I did some hunting around on the interweb and found a pretty good starting point in Circuits Today, but then, I needed to make some modification and tweaking of the circuit. I wanted to add in a toggle switch, a DC power socket and a 2 pin screw terminal into the design to make it easier to make and use.
12V NE555 PWM Controller – [Link]
Login
