![15V 1A Dual Output Flyback DC-DC Converter 15V 1A Dual Output Flyback DC-DC Converter](https://www.electronics-lab.com/wp-content/uploads/2017/09/IMG_0366.jpg)
+/-15V 1A Dual output DC-DC converter is a tiny board built using Transformer from Renco and LM2587-ADJ IC from Texas instrument. Input supply 18-36V DC. The LM2587 regulators is monolithic integrated circuit specifically designed for fly back, step-up (boost), and forward converter applications. The power switch is a 5.0A NPN device that can stand-off 65V. Protecting the power switch are current and thermal limiting circuits, and an under voltage lockout circuit. This IC contains a 100 kHz fixed frequency internal oscillator that permits the use of small magnetics. Other features include soft start mode to reduce in-rush current during start up, current mode control for improved rejection of input voltage and output load transients and cycle-by-cycle current limiting. An output voltage tolerance of ±4%, within specified input voltages and output load conditions, is ensured for the power supply system.
- Supply Input 18-36V DC
- Output +/-15V DC, 1Amp
- On board trimmer potentiometer for Fine voltage adjust
- Operation Frequency 100 KHz
15V 1A Dual Output Flyback DC-DC Converter – [Link]
