![16 Channel InfraRed remote controller 16 Channel InfraRed remote controller](https://www.electronics-lab.com/wp-content/uploads/2016/06/16-Channel-Infra-Red-remote-controller-001.jpg)
16 Channel Infra-Red remote controller is based on PIC16F73 Microcontroller from Microchip. The receiver part follows RC5 (Philips) Code Format. Tiny receiver provides 16 latch outputs or 8 Latch + 8 Momentary outputs by closing Jumper J1. All outputs are TTL and can drive Relay board or solid state relay. The circuit uses TSOP1738 Infra-Red receiver module which provides high degree of noise immunity against interfering light source.
- Supply Remote Transmitter RC5 Philips 2XAAA Battery
- Supply Receiver 7V to 12V DC
- Modulation 38Khz
- Philips RC5 Code Format
- Operating range up to 20 feet
- 2 Pin Screw Terminals for Supply Input
- On Board Power LED
- Onboard VT (Valid Transmission) LED
- All Outputs TTL Level provided with Header Connector
- Jumper (J1) for Mode Selection
- J1 Open 16 Latch Outputs
- J1 Closed 8Latch + 8 Momentary
16 Channel InfraRed remote controller – [Link]
Login
