![18 PIN PIC Development Board with Header IO 18 PIN PIC Development Board with Header IO](https://www.electronics-lab.com/wp-content/uploads/2016/10/18PIN-PIC-DEVELOPMENT-BOARD-IMG2.jpg)
PIC16F 18-pin Development Board will help you with your prototyping. It works with any of Microchip’s 18 pin of 16F PIC microcontroller.
- All ports terminating in separate box header with 5 VDC source option
- ICSP connector for programming for the PIC’s with ICD support
- Jumper selectable on board pull up resistor for PortA.4 pin on the microcontroller
- Bridge in the input provides any polarity DC supply connection to the board
- Jumper selectable 20 MHz crystal source
- Onboard +5V Voltage regulator
- Four mounting holes of 3.2 mm each
- PCB dimensions 56 mm x 55 mm
18 PIN PIC Development Board with Header IO – [Link]
Login
