![The only 2.2″ TFT designed to fit 1U front panels The only 2.2″ TFT designed to fit 1U front panels](https://www.electronics-lab.com/wp-content/uploads/2019/07/DT022CTFT-S.jpg)
The DT022CTFT is a 2.2 inch TFT LCD module with 240 x 320 RGB resolution. This LCD module is the only high resolution 2.2” TFT on the market that is designed specifically to fit 1U rack mount equipment. The a-Si TFT LCD uses a single chip driver (Ilitek ILI9341) that provides a full color display mode of 262K colors. This slim 2.2” LCD module includes a color TFT LCD, a driver IC, FPC, and a white LED backlight unit.
240×320 2.2″ TFT Display designed to Fit 1U Height for Rack Mount Equipment
- Diagonal Screen Size 2.2 inch
- Display Resolution 240 (RGB) x 320
- Viewing Angle 6 o’clock
- Interface Type RGB or MCU
- Brightness 330 cd/m2
- LCD Driver IC Ilitek ILI9341
- Module Size (w x h) 38.5 x 56.16 mm
- Active Area (w x h) 33.84 x 45.12 mm
- Pixel Size 0.141 x 0.141 mm
- Operating Temperature -20 ~ 70°C
more information on www.displaytech-us.com
Login
