![200V DC High voltage pocket generator 200V DC High voltage pocket generator](https://www.electronics-lab.com/wp-content/uploads/2018/10/IMG_20181003_164820.jpeg)
Aki made this DIY pocket HV generator:
There are times you find yourself looking for a relatively high voltage (100V to 200V often in my case) but low current DC power supply. I have zener diodes that are higher than 30V, which makes the lab supply useless, and filament LEDs with forward voltage over 60V. When I need to test them quickly, I used to hook up a simple rectifier circuit to a variable AC power supply (nothing more than a slidac with isolation transformer). While this gets job done, the setup is capable of supplying much too high current (1A or more), so I was always very nervous and extra careful in handling the circuit. All I need is a little HV generator that gives me around 200V DC and only capable of supplying a milliamp or less. Realizing that I do have such design available – one of the Nixie supply circuit – I just decided to put one together to use.
200V DC High voltage pocket generator – [Link]
