![28.8MHz TCXO with +-1ppm Stability 28.8MHz TCXO with +-1ppm Stability](https://www.electronics-lab.com/wp-content/uploads/2016/04/28.8MHz_TCXO_Schematic-1024x708-e1459752879696.png)
Craig document his process of building a Better RTL-SDR TCXO with +-1ppm stability over 0C-55C range.
Its hard to beat the cost and versatility of the ubiquitous RTL-SDR dongles, but the temperature stability of their reference oscillators isn’t sufficient for some applications. While the internal 28.8MHz quartz crystal in these units can be replaced by a high quality temperature compensated oscillator, these tend to be relatively expensive and/or difficult to source.
28.8MHz TCXO with +-1ppm Stability – [Link]
Login
