![2X L298 Dual DC Motor Driver Board for Robots 2X L298 Dual DC Motor Driver Board for Robots](https://www.electronics-lab.com/wp-content/uploads/2016/12/L298-Dual-DC-Motor-Driver-Board-IMG2.jpg)
2x L298 H-Bridge Dual Motor driver project can control two DC motors connected to it. The circuit is designed around popular dual H-Bridge L298 from ST. Motor supply 7V To 46V DC, Load 2Amp Each Channel.
- Motor supply V2: 7 to 46 VDC
- Logic Supply V1 : 5V DC
- Input Signal: Enable, Dir. , PWM
- Board Provides Current Feed Back ( On Board Shunt Resistor)
- Control Logic Input: Standard TTL logic level
- Output DC drive to motor: up to 2A + 2A
- External Diode Bridge for protection
- On Board 5V Power LED
- On Board Motor Supply LED
- 10X Box Header Connector for Inputs and PWM
- Header Connector For Logic Supply
- Screw Terminal for Motor Connections
- Screw Terminal For Motor Supply
2X L298 Dual DC Motor Driver Board for Robots – [Link]
Login
