The project described here is a 3 channel capacitive touch sensor based on CAP1203 chip from Microchip which is a multiple-channel capacitive touch sensor controller. It has 3 x individual capacitive touch sensor inputs with programmable sensitivity for use in touch sensor applications. 3 x touchpads are provided on PCB to detect the touch. Each sensor input is calibrated to compensate for system parasitic capacitance and automatically recalibrated to compensate for gradual environmental changes. The CAP1203 includes Multiple Pattern Touch recognition that allows the user to select a specific set of buttons to be touched simultaneously. If this pattern is detected, a status bit is set and an interrupt is generated. The CAP1203 has Active and Standby states, each with its own sensor input configuration controls. Power consumption in the Standby state is dependent on the number of sensor inputs enabled as well as averaging, sampling time, and cycle time. Deep Sleep is the lowest power state available, drawing 5µA (typical) of current. In this state, no sensor inputs are active, and communications will wake the device.
3 Channel Capacitive Touch Sensor with I2C – [Link]
Your blog gave me proper knowledge about capacitive sensors. These CAP1203 include Multiple Pattern Touch recognition that helps us to select a specific set of buttons to be touched simultaneously. But these electrotechnical sensors are to be durable and their quality, performance depend upon their brand. So these should be purchased from authorized dealers.
