Linear Technology Corporation announces the LT3089, a rugged 800mA wide input voltage range linear regulator with key usability, monitoring and protection features. The device has an extended safe operating area (SOA) compared to existing regulators, making it ideal for high input-to-output voltage and high output current applications where older regulators limit the output. The LT3089 uses a current source reference for single resistor output voltage settings and output adjustability down to 0V. Output current limit can be set externally with a single resistor. This regulator architecture, combined with low millivolt line and load regulation, enables multiple ICs to be paralleled easily for heat spreading and higher output current. The current from the device’s current monitor can be summed with the set current for line-drop compensation, where the output of the LT3089 increases its current to compensate for line drops.
36V, 800mA Robust Linear Regulator Has Extended SOA – [Link]
