![4.3” EZ Grip IPS TFT Displays 4.3” EZ Grip IPS TFT Displays](https://www.electronics-lab.com/wp-content/uploads/2020/09/NHD_4_3_800480EZ_ASXP_CTP_Newhaven_Display_Intl_Optoelectronics_DigiKey.png)
Newhaven Display’s effortless EZ Grip IPS TFTs make mounting easy with sleek, simple designs
Newhaven Display’s 4.3″ EZ Grip TFTs deliver high-quality images and reliable performance with a built-in mounting interface for simple installation and sleek, seamless integration in applications. These 4.3″ displays are equipped with IPS technology to bring a wide range of viewing angles and accurate color representation on TFT LCDs.
These 4.3” TFTs are ideal for integrated displays in any lighting conditions. The EZ Grip design allows the display to sit flush with its application when mounted, allowing for easy installation and a streamlined appearance.
- EZ grip mounting
- 4.3″ IPS TFT
- Built-in controller
- High-brightness LED backlight
- 800 x 480 pixels
- RoHS compliant
- Optically-bonded capacitive touch panel with I²C interface
- 24-bit parallel RGB interface
- High-brightness white LED backlight (850 cd/m²)
- Wide temperature range: -20°C to +70°C
more information: www.newhavendisplay.com
Login
