![4 Channel RC Servo Controller Board 4 Channel RC Servo Controller Board](https://www.electronics-lab.com/wp-content/uploads/2016/05/4-CHANNEL-RC-SERVO-CONTROLLER-BOARD-003.jpg)
This PIC microcontroller based RC driver is able to control 4 RC Servo by on board independent 4 potentiometer , 4X3PIN header for RC servo interface, screw terminal for supply input, on board power LED, optional 4X3PIN header connector for external potentiometer.
- Microcontroller based design for greater flexibility and ease of control
- Individual servo controlled via onboard preset or external potentiometer
- Power supply input 5 VDC
- Screw terminal connector for easy connection of the input power supply
- Protection diode for reverse supply
- Berg connector for connection of Servos
- Power-On LED indicator
- Four mounting holes of 3.2 mm each
- PCB dimensions 56.52mm x 64.14 mm
4 Channel RC Servo Controller Board – [Link]
Login
