![4 Channel Relay Board 4 Channel Relay Board](https://www.electronics-lab.com/wp-content/uploads/2016/11/4-CHANNEL-RELAY-BOARD-I044-500x500-1.jpg)
4 Channel Relay Board is a simple and convenient way to interface 4 relays for switching application in your project. Very compact design that can fit in small area, mainly this board is made for low voltage applications.
- Input supply 12 VDC @ 170 mA
- Output four SPDT relay
- Relay specification 10A/24V DC
- Trigger level 2 ~ 5 VDC
- Header Connector for connecting power and trigger voltage
- LED on each channel indicates relay status
- Power Battery Terminal (PBT) for easy relay output and aux power connection
- Four mounting holes of 3.2 mm each
4 Channel Relay Board – [Link]
How to process for buying this.
check your email for the details.
