![40 Pin & 28 Pin dsPIC Development Board 40 Pin & 28 Pin dsPIC Development Board](https://www.electronics-lab.com/wp-content/uploads/2016/10/40-Pin-28-Pin-dsPIC-Development-Board-PIC1.jpg)
The dsPIC Development board has been designed mainly for Motor dsPIC30F4011 Digital Signal Controller in the 40-pin motor control socket and dsPIC30F4012 28 Pin digital signal controller, the board can also be used with other dsPIC ICs. Board provided with 3.3V and 5V regulator, crystal oscillators and a programming connector. In addition, the board is populated with dual header connector for all I/O, reverse supply protection diode, onboard 3.3V & 5V LED, Screw terminal for supply input, push button switch for reset, 6 pin header connector for programming, serial communication header connector, jumpers for multi serial communication option , electrolytic capacitor for filters. Optional provision for LM317T TO220 Regulator for 3.3V and 5V and Jumper for 3.3V or 5V power supply selection to power up the dsPIC.
40 Pin & 28 Pin dsPIC Development Board – [Link]
