![40 PIN & 28 PIN PIC18F USB Development Board 40 PIN & 28 PIN PIC18F USB Development Board](https://www.electronics-lab.com/wp-content/uploads/2016/10/PIC18F-DEVELOPMENT-BOARD-USING-PIC-18F4550-18F2550-2.jpg)
PIC18F USB Development Board will help you with your prototyping requirement with any 28/40-pin Microchip microcontroller supporting USB interface . The board has been tested using PIC18F4550 40 Pin & PIC18F2550 28 Pin Microcontrollers.
- All ports terminating in separate Box Header with 5 VDC source option
- ICSP connector for programming for the PIC’s with ICD support
- Bridge in the input provides any polarity DC supply connection to the board
- 20 MHz crystal source
- Onboard +5V Voltage regulator
- Four mounting holes of 3.2 mm each
- PCB dimensions 77 mm x 87 mm
40 PIN & 28 PIN PIC18F USB Development Board – [Link]
Login
