![400V – 5A Power Supply For Brushless Motor Drivers 400V – 5A Power Supply For Brushless Motor Drivers](https://www.electronics-lab.com/wp-content/uploads/2017/05/001-2.jpg)
Although the power supply design is specific to the Brushless Servo Drivers mainly for IPM Modules, the concepts and circuit design may be used for any power supply requires high voltage output up to 400V DC and 5 Amps. The power supply is an unregulated design with an option to allow connection to either 120V or 230V mains and also it can work with lower voltage for audio amplifiers by increasing capacitor value. The design uses fully integrated bridge rectifier, and multiple bus capacitors for low ripple, noise suppression, and provides high current reservoirs. Additionally the dc supply line have bleeder resistor R2 and R3 to drain the large reservoir capacitors PCB, mounted fuse holder provided for short circuit and over current protections, low ohm NTC used for inrush current at power start up, C1, C12, TX protects against turn on/off spikes and EMI noise reduction. This power supply can be used to drive Tesla Coils, Induction heaters, DC Motor drivers, Brushless DC motor driver.
400V – 5A Power Supply For Brushless Motor Drivers – [Link]
