![50 Segment Serial Bar-Graph Display Driver 50 Segment Serial Bar-Graph Display Driver](https://www.electronics-lab.com/wp-content/uploads/2017/04/C101-1.jpg)
The serial controlled 50 Segment Bar-Graph Display built using CAT4016 IC. Very useful projects for development Bar-Graph based, Temperature Meter, Interactive Games, Voltage Display, Current Display., Pressure Sensor, Magnetic field meter and PH Meter. Tilt meter, LUX meter.
The CAT4016 is a 16 channel constant current driver for LED billboard and other general display applications. LED channel currents are programmed together via an external RSET resistor. Low output voltage operation on the LED channels as low as 0.4 V (for 2 to 100 mA LED current) allows for more power efficient designs. A high−speed 4−wire serial interface of up to 25 MHz clock frequency controls each individual channel using a shift register and latch configuration.
50 Segment Serial Bar-Graph Display Driver – [Link]
Serial controlled 50 Segment Bar-Graph is very useful. I want more information about this Segment Bar-Graph. Do you have micro controlled supported LED bar graph in an extensive range in this product segment? Also please let me know the pricing.
Thanks for your comment. This bar-graph module can be used with any mcu via a serial interface and custom code. Unfortunately we don’t sell this as a product or kit.
